right tail light turn signal problem
Old Dec 28, 2008 | 09:39 PM
ILUVMY89's Avatar
Default right tail light turn signal problem
it barely lights up but when i have my hazards on it lights up all the way ALSO my front left headlight does the same thing it barely has any glow some of the wires to my brights are disconnected and i need a wiring diagram to see were the y go
Old Dec 28, 2008 | 11:47 PM
02StanGT's Avatar
Default RE: right tail light turn signal problem
I'm not sure what year you have, but by your name I will assume it's an 89. If it is anything like the 4th gen, you have separate flasher modules, one for the hazards, and one for the turn signals. Since it only acts up with the signals, and not the hazards, you might try the signal flasher module. As for the headlight, you might check for corrosion in the plug/socket or it just might be a bad/old bulb.
Old Dec 29, 2008 | 12:18 AM
ILUVMY89's Avatar
BOUGHT NEW BULB THATS NOT THE PROBLEM INSIDE THE SOCKET IS THAT BULB GREASE I DIDNT PUT IT IN THERE BUT IT LOOKS LIKE PUTTY AND ITS IN ALL THE SOCKETS SO IM THINKIN THE PREVIOUS IDIOT THAT OWNED THE CAR PUT IT IN THERE TRIED TO CLEAN IT OUT BUT THAT STUFF IS EVERYWERE
Griffir
Mar 28, 2015 12:11 AM
Patrick Quentin Musick
Apr 13, 2013 06:56 AM
Dillon5224
Feb 19, 2010 02:53 PM
Andrew*B
Jun 27, 2008 11:35 AM
bill12690
May 30, 2007 12:57 PM
