Memory loss?
Old Dec 11, 2008 | 12:06 AM
kyleag89's Avatar
Default Memory loss?
Ok so I have a 91 Camaro RS. I have replaced my already aftermarket head unit with a new one, because when you turn off the car all the memory is lost. All my preset stations and clock are lost. So now that I narrowed it down to faulty wiring in the car.....what wouls cause the radio to loose its memory? Thanks in advance
Old Dec 11, 2008 | 12:33 AM
Skippysnax's Avatar
Default RE: Memory loss?
its very simple, on an aftermarket radio there is an accessory wire (red) which actually runs the radio. And a constant power (yellow) which is "constantly" powered, this is the wire that saves your memory. i can already tell u that the yellow constant was tied into the accessory.[:'(]
Old Dec 11, 2008 | 12:44 AM
SpecterGT260's Avatar
Ninja Administrator
did you attempt to do this from scratch? most install kits will ahve a color coded harness that snaps into your factory plug,and then you splice the like-colored wires.
Old Dec 11, 2008 | 12:55 AM
Skippysnax's Avatar
ya man wal mart has those harnesses for like 7 bucks, if u want a metra harness get one at cc or bb for $20, u need the 70-1858
camarojunkie
Sep 4, 2012 02:01 AM
maroman209
Sep 20, 2009 11:46 PM
camaro girl
Apr 9, 2007 05:24 PM
00camaro00
General Racing/Tech
Jan 23, 2007 09:47 PM
