Memory loss?
Ok so I have a 91 Camaro RS. I have replaced my already aftermarket head unit with a new one, because when you turn off the car all the memory is lost. All my preset stations and clock are lost. So now that I narrowed it down to faulty wiring in the car.....what wouls cause the radio to loose its memory? Thanks in advance
RE: Memory loss?
its very simple, on an aftermarket radio there is an accessory wire (red) which actually runs the radio. And a constant power (yellow) which is "constantly" powered, this is the wire that saves your memory. i can already tell u that the yellow constant was tied into the accessory.[:'(]
RE: Memory loss?
did you attempt to do this from scratch? most install kits will ahve a color coded harness that snaps into your factory plug,and then you splice the like-colored wires.
RE: Memory loss?
ya man wal mart has those harnesses for like 7 bucks, if u want a metra harness get one at cc or bb for $20, u need the 70-1858
