Headlights + Fogs in a 4th Gen
Old Jul 4, 2008 | 10:51 AM
Ozzker's Avatar
Default Headlights + Fogs in a 4th Gen
Okay, So i have seen a couple 4th gen 93-97 Camaros going around at night with their driving lights, hi-beams, and fog lights all on at once. I know that the car (at least my car) has something built into it so that this can't happen. Whenever I switch the hi-beams on, the fogs go off. Can anyone tell me how to by-pass this so I can have them all on at once?
Thanks!!
Old Nov 2, 2008 | 01:21 AM
Skippysnax's Avatar
Default RE: Headlights + Fogs in a 4th Gen
you can just manually wire the foglights to the regular lights, so that those four come on when u turn on ur lights, and then when u turn on ur brights all sixll be on....theres probably a better way though[:'(]
Old Nov 12, 2008 | 09:33 PM
Fortee's Avatar
Theres no reason in having both. If you have your brights on in fog, the light will bounce of the water droplets, and you wont see anywhere. The fog lights are designed to go through the droplets.
Old Nov 13, 2008 | 10:59 AM
02StanGT's Avatar
There is a way. It involves grounding somewireonthe foglightrelay.
http://www.ls1tech.com/forums/stereo...w-hi-beam.html
Metalvayne
Jun 23, 2015 09:45 AM
dropkickray8
Feb 9, 2010 09:18 AM
camaro girl
Mar 22, 2008 02:10 PM
apex
Mar 6, 2008 05:11 PM
ctboy
Oct 23, 2007 06:40 PM
