Amp blowing fuses
Old Aug 10, 2008 | 07:53 PM
Street_Racer's Avatar
Default Amp blowing fuses
my amp keeps blowing fueses it now even with no subs hooked up whats up with my amp?
Old Aug 12, 2008 | 06:51 AM
RFxCamaro's Avatar
Default RE: Amp blowing fuses
retrace all your wiring and like i always say i need to know what make and model your amp is, il gladly help you if you pm me
Old Sep 23, 2008 | 08:13 PM
camaro76's Avatar
just get bigger fuses tell me what amp you are using and ill tell you what size fuse to put in
Old Nov 2, 2008 | 01:08 AM
Skippysnax's Avatar
well if the subs arent even hooked up its probably just grounding out somewhere and it doesnt matter what kind of amp u have, just find out where its gronding out, its best to start from the battery with a volt meter and work your way back testing about every 2 ft.
Old Nov 16, 2008 | 03:06 PM
srs's Avatar
srs
That sounds like a cooked amp.
vnctvega
Jun 23, 2012 01:31 PM
bashgod
Nov 25, 2009 11:56 AM
TJeep_1999
Jun 15, 2009 10:20 PM
jamoore5
LS Series Tech
Jun 8, 2009 03:14 PM
Little_Richie
Jun 5, 2009 09:24 PM
