Amp blowing fuses
my amp keeps blowing fueses it now even with no subs hooked up whats up with my amp?
RE: Amp blowing fuses
retrace all your wiring and like i always say i need to know what make and model your amp is, il gladly help you if you pm me
just get bigger fuses tell me what amp you are using and ill tell you what size fuse to put in
well if the subs arent even hooked up its probably just grounding out somewhere and it doesnt matter what kind of amp u have, just find out where its gronding out, its best to start from the battery with a volt meter and work your way back testing about every 2 ft.
That sounds like a cooked amp.
