Berger Panel Rattle With Subwoofers
Old Dec 30, 2009 | 02:58 PM
Blasko's Avatar
Question Berger Panel Rattle With Subwoofers
I remember from a long time ago, finding a post somewhere on how to fix this, but could not find it.
Basically I've had a sub in my car ever since i got it.
I finally got around to upgrading and now i have a JL12W6V2
It hits crazy hard, but now my Berger panel rattles outside the car.
If i put all of my weight on it, it wont rattle.
I plan to take my Berger panel off and paint it, so I figured I'd fix that while I'm there.
Any ideas?
I've never taken it off before so I'm unsure about what else is back there.
Also, I was thinking about dynamat, but i was worried about it getting wet from moisture and rotting/falling apart.
Any info would be appreciated.
Thanks ahead of time.
-Blasko
Old Jan 1, 2010 | 04:47 AM
RFxCamaro's Avatar
dynomat under panel
Old Jan 1, 2010 | 02:10 PM
Blasko's Avatar
I was thinking that, but was worried about it getting wet and rotting from moisture.
Or is this a non-issue?
I've never used Dynamat before
Old Jan 2, 2010 | 11:12 PM
greenarrow's Avatar
September 2009 ROTM
That tail panel shouldn't be rattleing unless there's a bolt missing along the middle section. Most rattleing on fbody's comes from the lincense plate or the spoiler. Make sure you got all the bolts in that thing, they are pretty easy to spot.
Old Jan 21, 2010 | 07:16 PM
Blasko's Avatar
Everything is tight, and the license plate doesn't rattle at all.
It's only the berger panel.
I have another one I'm prepping for paint right now, When I swap them, I'll mess with it more and Let you all know the dealio.
Old Feb 4, 2010 | 11:45 PM
greenarrow's Avatar
September 2009 ROTM
I just want to clear something up here, it's not called a berger panel. It's a tail panel, a berger panel is on a special edition berger camaro from the berger chevy dealer. And it really should be called a big block panel, because all the block camaro's in the 60's had a black tail panel.
Sorry, just erk's me when people call things something they aren't.
And back on topic, is there any cracks in the tail panel? I've installed some insaine systems in camaro/TA's and have never had the tail panel rattle. Your's is be the first I've heard of rattling. Are the tail lights in good? I mean I've got two 12's in my trunk that have been measured at 136 dBs and my tail panel doesn't rattle, the trunk lid and the spoiler rattle and that's it. The lincense plate did, but fixed that, can't fix the other stuff.
Old Feb 7, 2010 | 11:15 PM
Blasko's Avatar
Ber. Er.
Tail Panel has no cracks.
Tail lights are in correctly, and tight.
No Spoiler rattle, and no license plate rattle.
If I push against the panel, or against either tail light it isn't as intense, which is weird.
Maybe something behind it?
Old Feb 8, 2010 | 03:07 AM
greenarrow's Avatar
September 2009 ROTM
There really isn't anything behind the tail panel, just the body structure of the trunk. Are the two nuts on either end of the tail panel tight? There's those and then two in the middle. I wish I could give you more man.
Old Feb 8, 2010 | 10:07 AM
Blasko's Avatar
Yup, I check and tightened all 4, as well as the 4 plastic wingnuts for the lights.
I made sure nothing was behind the carpeting or stuck in there.
What else could it be?
FosterW
Mar 13, 2012 02:40 PM
SixShooterCamaro
Sep 4, 2009 02:16 AM
01camaro.dude09
Sep 17, 2008 06:19 PM
muscleman
Jul 13, 2007 04:59 PM
jarid2000
Dec 8, 2005 10:36 PM
