any questions?
Old Jan 11, 2006 | 10:02 PM
  #21
84z50HO's Avatar
Default RE: any questions?
hey bclewis, as far as you not wanting to cut the dash up in your 69, you have several options.1 good ol shaft radio.2 metra and ami makes an universal drop box kit that can be used.3 go custom and creative.Example center consoule,glove box etc.4 run the shaft up front and you can always go with a rf modulated cd changer.Im not to sure if the shafts have changer controls.Ive been in this field for 15 years and am really surprised that pioneer and kenwood still have the same shafts(well different internal amps) plus some cosmetic changes.IF you need anything else or anyone for that matter, feel free to ask.
Old Mar 16, 2006 | 01:38 AM
  #22
Mpit52's Avatar
hey guys, i got a 89 camaro, and i wanted to put some subs in the back. i no theres not alot of room in the trunk, so i was thinking about just building like the top of a box and placeing it in that "trunk space". basically creating a complete box...is there any special way that i would have to build this box. like does it matter wat kind of sub's im goin to be putting in there.....cause i heard that Box designs r importante...
Old Apr 10, 2006 | 12:10 AM
  #23
84z50HO's Avatar
Depends on how much air space your subs required.Yes box specs are Very important.If you are just wanting to throw a piece of wood down over the hole back there, then i would go with free air subs.If not, then you would need some fiberglass,polly fill and liquid nails or silicone to seal the seams.What type and size subs are you wanting to use?I have an 84 and i measured and had a little over a cubic foot of air space there without removing the carpet etc.Other option is to reverse mount the subs.
Old Apr 27, 2006 | 05:28 PM
  #24
solidicex's Avatar
i was wondering if anyone has blueprints for a sub enclosure that would fit in a 94 camaro z28, for two 12" subs or two 12" s and two 10"s
Old Aug 7, 2006 | 12:48 AM
  #25
80z/28's Avatar
I have a 1980 camaro z/28 how do I go about putting two 10 inch subs in the trunk and keeping it clean I dont want a big bulky box taking up my whole trunk could someone tell me where i can go and get custom boxes make or a web site that i can go to the check out thanks 80z/28
Old Aug 17, 2006 | 07:39 PM
  #26
02renegade's Avatar
80z/28,
Fitting two tens in the trunk is not a big deal, but the trunk is small to begin with so it doesnt take much to lose most of the trunk space, if you dont want one big box you can get two single boxes that are a little more flexible as far as moving them around in the trunk. I have 4 8's in my '78 but then again I took up my whole trunk just for audio gear.
Old Sep 16, 2006 | 09:19 PM
  #27
mombofan1's Avatar
I just got 1985 2.8 liter camaro and I have my old panosic cd player that I took out of the last car.... It has all wires that arn't spiced on the car the wires are spiced I would really not like to spice my wires and even if I did the colors don't match up any sugestions
  #28
mombofan1's Avatar
Nick~mombofan1@aol.com
Warpig
Apr 20, 2009 09:33 PM
bigjsmashman
Feb 21, 2008 11:05 PM
nj93zkid
Feb 24, 2007 01:20 PM
dubbs95
Oct 21, 2006 01:29 PM
