annoying alternator whine
Old Sep 18, 2008 | 04:02 PM
mtn_maro's Avatar
Default annoying alternator whine
so my amp puts out the dredded alternator whine and yesterday i was trying to fix it. i thought i did. turned out to be a bad ground on the amp. fixed it. fired up the car and it was gone. an hour later when i went to work it came back. now i cant figure out whats causing this. can anyone help? oh yeah its an 87 z28 and a vr3 200w amp
Old Sep 19, 2008 | 05:56 AM
RFxCamaro's Avatar
Default RE: annoying alternator whine
it is something with your groundim guessing you have a pioneer deck? happens to alot of them make sure you ground all your grounds to unpainted parts and check your harness for a rip in the ground cable or get a ground loop isolator i see them for like 20ish
http://cgi.ebay.com/GROUND-LOOP-ISOL...QQcmdZViewItem
Old Sep 19, 2008 | 12:39 PM
mtn_maro's Avatar
no its a cheap panosonic deck. i had a feeling it would be the ground. the only wierd thing is that i fixed it and within an hour it came back
Old Sep 29, 2008 | 11:47 PM
mtn_maro's Avatar
well that solves it. ended up being a bad amp. so now instead of a 200w vr3 amp i have a 600w boss amp.
Old Oct 20, 2008 | 02:46 PM
1998rsy87's Avatar
i think you couldve solved the prob with the old amp. i mean i have some amps that make the noise and some that dont. ive solved the problem before by running a 12awgwirefrom the amp direct to the deck. and ive solved it by running the power wires and RCA cables on opposite sides of the car.
ckrummy
11
Nov 22, 2013 03:02 PM
aappss01
Aug 22, 2012 08:28 PM
BudBrown
Jun 18, 2012 12:09 PM
JaySan
Dec 11, 2006 02:20 AM
