15 in subs
You would have to custom build a box to fit your Camaro if you want two 15"s... Oh and you forgot the link... And if it says 84-92, it obviously will not fit a 95. I've seen people custom build their own box for 93-02 Camaros that fit two 15"s. Good luck and welcome aboard the forum
http://www.topedgeonline.com/Camaro_...8492cam215.htm
lol i noticed i forgot something after i walked away
It's the thickness of the wood they used to construct the enclosure. 5/8 is weak and too thin for 15's. 3/4 is a must!
Here! I found a box for you:
http://www.onlinecarstereo.com/CarAu...er_NCM215.aspx
http://www.crutchfield.com/p_044CFT2...ay.html?tp=129
This is basically what you want. If you want something premade ^
Here is my sub setup, I have no idea what the box is, it's just what the guy already had in there. I figured it was worth the extra 250.
On this note, Probably added close to 70 (estimate) pounds to the car.
