wanting new ram air hood 96camaro
Old Sep 18, 2012 | 06:18 PM
96maro's Avatar
Default wanting new ram air hood 96camaro
Just wondering if anyone knew where i could get a hood for my 96 camaro, i want the ram air that is FUNCTIONAL, my car is black so painted would be good but not a must. Either new or used w/e works.
thanks!
Old Sep 18, 2012 | 07:32 PM
Failed Devices's Avatar
Functional really is meaningless. Its pretty much functionless on even WS6 cars, so don't get your hopes up that you will pickup power or have a true "ram air" effect.
IMO I like the small wide cowl hoods on the 93-97 cars. Not sure what other options you would have besides the SS style
Old Sep 19, 2012 | 07:28 PM
96maro's Avatar
the reason i wanted one is my car gets HOTTTT, only when im sitting in town at stop lights or in campus, i know these cars are notorious for it, nothing is wrong.. it hasn't overheated but its gotten close, i need 2 get some more air in there to cool things off any ideas?
Old Sep 19, 2012 | 08:32 PM
A ram air would won't do any good when just sitting at a light or idling. Where do you live? If your car is sitting above normal operating temperatures then something is wrong. Have you done the basics, flushing the radiator, new coolant and thermostat?
Old Sep 19, 2012 | 10:17 PM
They make aftermarket kits to turn your cooling fan on earlier, or manually with a switch, which will bring down your low speed engine temps.
Or, if you're electrically inclined, you can DIY. Do some research.
Old Sep 19, 2012 | 11:07 PM
96maro's Avatar
not a thermostat but flushed yes, i know the stat is good, my buddy had to do that switch for his same year, where would i go about getting a kit though?
Old Sep 19, 2012 | 11:27 PM
This one is a manual override, but the fan still works like it does now if you don't switch it on: SLP Manual Fan Control Switch for 93-02 Camaro and Firebird
Old Sep 20, 2012 | 08:20 AM
Edwardgp's Avatar
One thing will fix the low speed overheating, you need to get more air flowing through the radiator. The fans would be a great place to start.
Old Sep 20, 2012 | 08:23 AM
Cheeks's Avatar
August 2011 ROTM
I have this on my car, it works great and is simple to install
mp734
May 16, 2014 09:04 PM
critt86
Sep 28, 2013 02:33 PM
Clear
Jul 18, 2011 07:06 PM
bseverson34556
Nov 9, 2009 12:50 PM
chevychick99
Mar 18, 2007 04:28 AM
