wanting new ram air hood 96camaro
Just wondering if anyone knew where i could get a hood for my 96 camaro, i want the ram air that is FUNCTIONAL, my car is black so painted would be good but not a must. Either new or used w/e works.
thanks! |
Functional really is meaningless. Its pretty much functionless on even WS6 cars, so don't get your hopes up that you will pickup power or have a true "ram air" effect.
IMO I like the small wide cowl hoods on the 93-97 cars. Not sure what other options you would have besides the SS style |
Originally Posted by Failed Devices
(Post 645137)
A ram air would won't do any good when just sitting at a light or idling. Where do you live? If your car is sitting above normal operating temperatures then something is wrong. Have you done the basics, flushing the radiator, new coolant and thermostat?
They make aftermarket kits to turn your cooling fan on earlier, or manually with a switch, which will bring down your low speed engine temps.
Or, if you're electrically inclined, you can DIY. Do some research. |
not a thermostat but flushed yes, i know the stat is good, my buddy had to do that switch for his same year, where would i go about getting a kit though?
This one is a manual override, but the fan still works like it does now if you don't switch it on: SLP Manual Fan Control Switch for 93-02 Camaro and Firebird
One thing will fix the low speed overheating, you need to get more air flowing through the radiator. The fans would be a great place to start.
(Post 645243)
