work in
work in
well got the car moved to the shop yesterday, which was a pain in the back side. it had sat in a field for two or three months before i had found it. the two back tires where flat, the transmission was hanging down on the ground. once that was fix got it pulled out form the hole it sunk into, up on the dolly and to the shop.
the previous owner had blown the factor engine and pulled it, thinking he was going to replace it with another 3.4 he had.
so i found a 3.4 with 70,000 on it I'm in the process of dropping into the car so i can drive it around, while i rebuild the factory engine.
worked all day yesterday cleaned the block, changed all the gaskets on the new power unit, new motor mounts you know just little stuff so i have no issues down the road,
today i got the engine into the car but got P/O couldn't get the driver side of the block to but up to the bell housing... got the passenger side in, but for what ever reason could not get the driver side in.. i only need a half an inch and then i can thread the bolts on.. but on the up side i did get the engine in and some what together..lol
sorry no pics for got ill get some up the next time i work on it, most likely be next weekend ..
