Won't stay started
This video should explain it. She starts, idles up a little then dies. You give her gas and she dies. Changed fuel filter with thoughts of her starving for fuel.
It's a 99 with the v6. Recently changed plugs and wires. Then had a random misfire on #6 do changed coil pack and this cured the problem. I removed the air box hose to see tb response. It flutters when turning the key then when she dies a puff of air comes out. More like she is choking. I'llt try to fix the video.
OK let me restate about fuel pressure. Bought a gauge and the fitting it didn't have was for the camaro. Air comes out then fuel. Pressed my fitting on my car and it squirts out hard. Is there a fuel pressure regulator before I jump into a fuel pump?
