Won't stay started
what does the gas gauge say. if your getting air it sounds like you may be running out of gas. the 4th gens fuel gauge is not the best, my first ran out just above 1/8th tank.
with air there is only a couple things it could be. the line is under pressure from the pump to the injector so no air can get in there. has to be in the pump or your outta gas. if a cheap china pump was used then i would not be surprised to see a failure. do the hatch if it does not have one. once in it cuts fuel pump change to a 1 hr job.
