Window help
I have a 2000 camaro with power windows. The problem is that sometimes when i roll it up it stops about halfway. it is on the passenger side. But if i wait like 10 seconds it will roll up more. Could it be that i need a new motor window . Any help would be appriciated
My windows on my 89 do this from time to time also, I thought it was because I was leaning on the door the first time but now that I read this post I'm thinking maybe it needs some lube...
I had the exact same problem in my 2000 'maro. I had to replace the whole window motor which ran me around 150 bucks. I dont know if the lube would fix it or not, but if you can find a cheap motor and somebody to install it (if you need somebody to) without spendin too much, I would just go ahead and replace the motor. My window works like its new now.
cornmuffin
07-24-2014 10:22 AM
