window and more
Old Jul 17, 2007 | 06:16 PM
camroadrenaline's Avatar
Default window and more
my power window went out. I uess i just need to replace the motor right? Also, my car smells just a bit and sometimes i have to turn it over a few times to start it but not all the time. Im thinkin I got a tank of bad gas. What do you guys think
Old Jul 17, 2007 | 06:21 PM
bluovlh8er's Avatar
Default RE: window and more
can you post a clip of this smell?
lol
Old Jul 17, 2007 | 06:23 PM
Its like a rich smell. Like maybe im not burnin it quick enough
Old Jul 17, 2007 | 07:28 PM
bluovlh8er's Avatar
if its rotten eggs your cat is bad.
take it, hold it by the tail, and gut the s. o. b. lol
Old Jul 17, 2007 | 07:56 PM
How exactly do you gut one? Is it hard?
Old Jul 17, 2007 | 07:59 PM
bluovlh8er's Avatar
this is very technical but here it goes...
1. take the cat off
2. put a pipe inside it...
3. jam, twist, hit. all the crap out of it. (clean it)
4. 200 extra h/p
j/k but it will sound better.
Old Jul 17, 2007 | 08:07 PM
Ok man thanks. Ill give it a try...does it come off easy..with bolts or something? and i dont have to remove anything else to get to it do i?
Old Jul 17, 2007 | 08:12 PM
bluovlh8er's Avatar
well you disconect it from the heders/manifold... then disconect it fron the y-pipe. then gut it. and put it back on.
Old Jul 17, 2007 | 08:16 PM
t9ojetpilot's Avatar
[X(] what year is the car?? if your getting a sulpher smell its not the cat going bad its a rich condition as in too much fuel. you need to find the problem not fix the symptom. if cars are smog tested in your area dont count on passing the test once the cat is removed. kurt
Old Jul 17, 2007 | 08:20 PM
bluovlh8er's Avatar
oh just gut the cat.
