Why is my AC/HEAT only blowing at my feet?
Old 02-11-2011, 06:45 PM
C4r1b0u's Avatar
Default Why is my AC/HEAT only blowing at my feet?
I have both working AC/heat but for some reason it will not blow out of the dash vents. It comes out strong by my feet and when i put it on defrost it still comes out by my feet but i can feel a little blowing out of the defrost vent.
What is going on??
Old 02-11-2011, 07:09 PM
Chaotic94's Avatar
September 2011 ROTM
Maybe the HVAC came loose. What year is your car? v6 or v8?
Old 02-11-2011, 07:11 PM
Massey's Avatar
Check the vacuum lines going to the hvac controls and also the line that heads out into the engine bay. It should have a vacuum canister that it goes into somewhere near the battery. if that is not connected the heater controls will not work.
Massey
Old 02-12-2011, 10:12 AM
mrfreez's Avatar
Could also be your heat resistor that's burnt out. It's under the dash attached to the blower motor.
Old 02-12-2011, 11:42 AM
Massey's Avatar
The heat resistor would only effect the blower motor. It appears that he has air blowing just not where he wants it.
Massey
Old 02-12-2011, 12:32 PM
C4r1b0u's Avatar
its a '94 v6
Old 02-12-2011, 12:52 PM
Massey's Avatar
What I posted first still applies to a 94 V6
Massey
Old 02-12-2011, 02:30 PM
C4r1b0u's Avatar
i feel stupid because i dont know where im looking
Old 02-12-2011, 02:55 PM
ghostpopi's Avatar
i had same probelm with mine, look under hood passenger side up near windshield close to cpu is 3 way vacuum tee one of mine hoses was broken i got a new tee an pugged them back in an now i get air flow from where i set the dial defrost floor or dash vents.
Old 02-13-2011, 03:55 AM
ccrunner1104's Avatar
Same thing here, it was a quick fix
Quick Reply: Why is my AC/HEAT only blowing at my feet?
