Where is the IAC Valve
Old 01-28-2008 | 09:03 PM
02StanGT's Avatar
Default RE: Where is the IAC Valve
I was just curious. I know the PCM calls for extra fuel when the IAT reads cold. Especially when you start it after the engine has cooled.
Old 01-28-2008 | 09:07 PM
02StanGT's Avatar
I drew a red arrow to what I believe is the wire for the IAT. It should be mounted in your intake.
[IMG]local://upfiles/1426/E9B3F1B14E1846AB908077B49B2551AE.jpg[/IMG]
Old 01-28-2008 | 09:58 PM
twistedpyro's Avatar
My car doesnt have black smoke comming out the back so I guess I just assumed it was lean. I know where the IAT sensor is, but where is the IAC valve?
Old 01-28-2008 | 11:29 PM
That is a good picture of it. I couldnt find one that good online.
Old 01-29-2008 | 06:05 AM
02StanGT's Avatar
It's the same picture as yours. If you're thinking the IAC valve is causing it to run lean, I highly doubt it. Depending on where it's stuck at (assuming it's malfunctioned) you would have a high or low idle.
Old 02-01-2008 | 05:42 PM
Well, today I took my car to a mechanic to find the stupid IAC valve and he couldnt find it either. Then i went to another and they couldnt find it. So, quite confused I went to the gm parts guy and got a diagram for my motor to find out where the damn thing was. He printed out one but it wasnt there. I asked the parts guy what he thought about that and he said in a **** head tone, "Trying" to be a mechanic isnt easy. So pissed off because I knew I was right I somehow found the service tech supervisor and he looked my car up on the computer and found out that it doesnt have an IAC valve. Now I am sill stuck with my car Ideling irraticly when its cold and no IAC valve to check. Oh ya I replaced my IAT sensor and that wasnt it.
EagleRex
10-05-2009 04:14 AM
Labyrinth9
03-20-2008 09:15 AM
79camaro505
02-22-2008 08:02 PM
3.4CamaroCDOG
02-01-2008 07:22 PM
Quick Reply: Where is the IAC Valve
