What's Wrong
What's Wrong
I have a 95 3.4 5 speed. When i press the gas it will rev up before it catches. ex. i press gas when im in gear and it will rev up to like 4000 rpms then drop to 2000 and catch before it starts pulling. thanks in advance
how much doesw that cost
i just replaced the slave and master cylinder. the part that u bolt the slave cylinder onto (i believe the bellhousing) snapped off, so i gotta replace that now.
Just so you know you will still need to replace the clutch. A failed or broken Slave/master cylinder will not cause the clutch to slip it wil cause the clutch to not disengage.
so like 150 for the parts. how hard is it to put in a clutch
