What years engines will interchange 3.8?
Old Mar 15, 2009 | 04:21 PM
osduck5's Avatar
Default What years engines will interchange 3.8?
I have been looking at donor engines and am holding out to find one with less miles than what I have been finding. Does anyone know which year models engine will interchange with a 96 3.8? Replacing a 3.8 with a 3.8! I am finding some 2002 engines with fewer miles but I wanted to make sure that I am buying something that will be bolt up without having to make alot of changes before I buy.
Old Mar 16, 2009 | 01:54 PM
02StanGT's Avatar
All the 3.8 Camaro engines will interchange with it, but if you get a '99+ then you will have to swap your old intake manifold and throttle body onto the newer engine.
Old Mar 20, 2009 | 07:41 AM
chernabog's Avatar
I was going to ask the same question. I've got a 98 now, and want the intake off a 99+. I'm seeing the throttle body is different between the two, but does the old TB not line up with the 99+? Looking under the hood at a 2001, it really looks like the major difference on the driver's side is that the electronic throttle is there, and runs up to the plate of the intake. But do the bolt patterns line up otherwise?
Old Mar 20, 2009 | 11:06 PM
See my Build thread in my Sig. I am puting a 2002 in a 96. Upper intake and injectors are different. The changed the design of the front end to fit the LS1 and it seen they took advantage of that by making a taller intake. If you strip all the parts off the motor you can even use many of the FWD 3800.
greenmachine96
Dec 20, 2013 11:16 AM
charlie94
Oct 28, 2011 08:43 PM
typappy
Sep 27, 2009 03:56 PM
typappy
Sep 18, 2009 07:03 PM
kreaton
Jul 8, 2008 11:22 AM
