What hose is this?
Old 04-04-2008 | 09:22 AM
TomS68's Avatar
Default What hose is this?
Hey guys,
Just got to work in my Camaro and a hose decided to let go. Fantastic. Sat there steaming in the parking lot for all to see. Ha! Ha! Anyway I need to repair or replace this hose to get home but I need to know which hose this is. It's not looking easy. I've got a '93 V6 3.4. The hose I'm looking at is this hose: There is a section of hose 4 inches long that connectes the water pump to some metal tubing that routes under the alternator. That hose is fine. After the metal tubing that runs under the alternator there is another hose that runs from the metal tubing down and back into another section of metal tubing that leads back towards the firewall. It is this hose that sprang a leak. The goofy part about this hose is that attaches with a hose clamp to the tubing that runs under the alternator but on the other end the hose just seems to run into the steel tubing that goes toward the firewall. I don't see a hose clamp. What gives? How do I replace this section? I've got a NAPA autoparts store nearby. What is this hose and what's the deal with the hose seemingly running straight into steel tubing. Is this steel tubing a part of the part or can the rubber hose be replaced separately? I appreciate any help.
Thanks,
Tom
Old 04-04-2008 | 09:35 AM
02StanGT's Avatar
Default RE: What hose is this?
Sounds like a heater hose, based on your description of where it's going.
Old 04-04-2008 | 09:41 AM
TomS68's Avatar
It very well could be a heater hose but what is up with the wierd connection and how do you replace that? It doesn't look like you can just take a hose an unclamp the old one, put a new hose in there and clamp it up. The hose looks like it runs straight into steel tubing. There's no hose clamp.
Old 04-04-2008 | 09:52 AM
02StanGT's Avatar
Beats me. I know what you're talking about it's screwy.
mab6680
12-23-2010 08:01 PM
black95z28
04-19-2010 11:28 PM
Tonylig928
12-30-2009 07:38 PM
ShiftyMcCan
82-92 V8 Tech
08-23-2008 04:14 PM
chrshadil
08-21-2008 11:37 AM
Quick Reply: What hose is this?
