weird noise while driving?
Old 05-11-2009 | 10:05 AM
vinnysav's Avatar
Default weird noise while driving?
On my 98 camaro the passenger side rear wheel is making this weird noise while im driving. Almost like a whistling sound it's hard to describe, if anyone has had this problem or know what it is that be great
thank you
vinnysav
Old 05-11-2009 | 11:05 AM
niteman's Avatar
brake pads maybe? I know there are tabs on brake pads that let off a lil more than a whistling sound... but it could sound like that from the drivers seat...
could we get a lil more info?
Old 05-11-2009 | 12:31 PM
Tonylig928's Avatar
maybe the hub bearing? mine was making a sound and i replaced it and it stopped, now my front tranny bearing is making the sound =[ so check the hub bearing, maybe the trans bearing?
Old 05-11-2009 | 08:11 PM
01camaro231's Avatar
Question: Do you have chrome rims.?
Old 05-11-2009 | 08:18 PM
agree with niteman, sounds like brakes. do u have disk brakes on the back?
Old 05-11-2009 | 08:20 PM
Tonylig928's Avatar
on my bad rear i thought you said front.
Old 05-12-2009 | 08:52 PM
vinnysav's Avatar
sry I should of mentioned that I got new rear brakes a couple months ago so I don't think it would be the brake pads. The sound dosent happen all the time, sometimes when i start moving I'll hear this souund almost like a churping or a winding. It almost sounds like there something in there and it makes the noise once the wheel went all the way around.
Old 05-12-2009 | 09:24 PM
libertyforall1776's Avatar
Flaking chrome from the rims rubbing as the wheel spins can do it...
Old 05-12-2009 | 10:55 PM
Tonylig928's Avatar
jack up both the back wheels and try to move the drive shaft it it has some movement without the wheels moving get your rear end checked because i think thats the same thing that just happened to my car the rear was starting to go and check if theres fluid leaking from the rear that can also cause it from the mechanical parts in the differential.
Old 05-13-2009 | 12:55 AM
^^ yep check the level of the fluid in the rearend or have it changed and while u do that look around and see if theres oil leaking from the rearend anywhere, check behind the wheels also. if not brakes could be axle bearing. does the noise change when turning on the highway?
TEXASMAN1
06-12-2008 04:45 PM
biohazard
01-07-2008 05:47 PM
Saint_Ali
11-14-2007 12:45 PM
davidalvarez82@hotma
10-28-2006 03:28 PM
LS Series Tech
09-09-2006 08:45 PM
Quick Reply: weird noise while driving?
