Weird "check engine" problem..
I'm not following you on this one. Are we talking about changing the intake gasket or the ecm?
As far as those headlights go, cheap knockoffs, buy at your own risk. Same one's from an autoparts store would cost $50, so that tells you something right there. But those are not real HID headlights, just look a likes. Again, buy at your own risk.
He didn't tell me the codes, but i know him for years and he wouldn't lie to me for sure. He said that upper intake manifold gasket needs to be replaced.
i would think about taking it to a different shop. did you get the code numbers when it was scanned. if we know what the codes are we will have a better chance of finding the problem. oh and a 95 will not flash codes like a 93. you need a scanner or a aldl cable and program to get the codes to diagnose.
I put a brand new EGR valve in it. Thought problem would go away but i still get the code when i coast from 70. My mechanic said thats not big issue. And it really doesnt effect the way its running. By the way, we think that i do have a minor engine oil leak too somewhere around that, so we are going to replace em anyways.
Absolutely. I will take care of that gasket this weekend and post the results in. Thank you.
AmericanMuscle1989
Jun 25, 2013 10:38 AM
