Water neck
Old Feb 9, 2012 | 11:01 AM
Chevy101's Avatar
Default Water neck
The bleeder screw head is destroyed and I can't bleed my system. Anyone know where to get that entire piece?
Old Feb 12, 2012 | 02:06 PM
osduck5's Avatar
Try your local salvage yards Can you get the screw out or is it the part that the screw is in that is messed up?
Old Feb 12, 2012 | 04:09 PM
Chevy101's Avatar
That's what's messed up. The top of the bleeder screw is too damaged to unscrew
Old Feb 12, 2012 | 05:30 PM
so you cant get pliers or small vise grips on it?
Old Feb 12, 2012 | 05:55 PM
If your thermostat has a small bleed hole in the base of it (the disc part) as some do, it will bleed itself.
If not, you can drill an 1/8" hole in the stat and not worry about having to manually burp the system.
nutter67
Mar 26, 2013 11:41 PM
Chevy101
Apr 19, 2011 09:17 PM
67camaroGURL
Oct 15, 2010 01:00 PM
1994z28
Jan 1, 2008 02:27 PM
