Walking belt
With the engine off! Use a string if you can't fit a straight edge. Hold one end of string on pulley A, span across pulley B, pull tight and hold other end on pulley C. If string hits pulley B before C, or if there's a big gap between pulley B, something is out of alignment. Then keep working your way up the alphabet!
