valves or pistons?
Old Mar 29, 2007 | 10:26 AM
1993V6Camero's Avatar
Default valves or pistons?
I have a 3.4 V6. I have no compression in the #2 cylinder (middle on driver side) We adjusted the rocker arms, but still no compression. do you think it could be the valves or the pistons and rings?
Old Mar 29, 2007 | 02:29 PM
easmanz28's Avatar
Default RE: valves or pistons?
i would think it would be a blown rings, but ive been wrong before...
-al
Old Mar 29, 2007 | 05:39 PM
At this point it really does not matter. Wether rings or valves, the heads still have to come off in order to fix the problem.
Old Mar 29, 2007 | 07:48 PM
usarmyrangrs's Avatar
If you have a compression tester handy, apply it to the number two cylinder. Before you connect the tester, roll the engine over so that #2 is on BDC. A few squirts of motor oil into the hole should temporarily seal the piston on it's compression stroke. Connect the tester and see if this is true. If there is still no change, one can assume it may be a faulty valve and/or valvetrain components. If there is a compression spike, gear your attention more towards a piston ring.
emptysmile005
Feb 16, 2011 01:07 PM
Frankenstein
67-69 V8 Tech
Jul 7, 2010 06:28 PM
Orion
Jul 23, 2009 11:30 PM
SSsuperdave
Mar 28, 2007 01:01 AM
94CamaroSFI
Nov 4, 2006 06:28 PM
