V6-V8 swap: How to
Old 10-07-2010, 08:36 PM
Remy's Avatar
Nope. You either can fab up a set of mounts to fit on the small block or grab a tubular K-member that will fit it. I'd opt for the tube K-member to keep the weight off. The sbc is a lot heavier than an LS1 or it's iron block counterparts.
  #82
Old 10-14-2010, 09:59 AM
is there any way to fit a naturally aspirated sbc 355 in the engine compartment with out cutting the firewall to fit the distributor and the carborator? running a mallory unilite distributor
  #83
Old 03-12-2011, 08:38 PM
carterbrad94's Avatar
massey u can use the 5.3 just switch intakes thay put the same mores in the impala ss
  #84
Old 03-12-2011, 08:47 PM
im putting the 5.3l in my 94 but just the engine an trans an the wiring harness
  #85
Old 03-12-2011, 10:33 PM
Might want to look again. The impala is a FWD car, the throttle body is above the trans. On your camaro that would put you air cleaners about where you radio is.
If you have read all of this thread you know all the problems you are facing. Please, please prove us wrong and make a detailed thread on how you get all the older Camaro sub systems to work with a 15 year newer PCM.
Thanks.
  #86
Old 03-12-2011, 10:49 PM
no there rear wheel drive
  #87
Old 03-12-2011, 10:59 PM
my bad not the new ones
  #88
Old 03-12-2011, 11:03 PM
either way the 5.3l is fine in a 94 camaro
  #89
Old 03-13-2011, 01:55 AM
Massey's Avatar
Well then lets see it be done. I would love to see how you are going to integrate the 2 PCMs to work together or retrofit the newer PCM into the older body. How about the ONSTAR system in the newer car are you going to keep that intact as well? Also how are you going to deal with the transmission? that works with the older PCM not the newer one... Unless you are using a truck 5.3L engine which is taller than the LS1 and wont fit under the cowl... Hmmm Yea I would love to see this build.
Massey
  #90
Old 03-13-2011, 07:45 AM
Are you saying you have already done it or know of someone who did? Please post a link.
Understand that if you can figure how the average guy in a average garage could do this you would be a hero to thousands. Right now there is no good alternative for early V6 owners that does not cost more then the car will be worth when done. I have been watching the 4 gen boards (not just this one) for the last 5 years and I have heard this 5.3 idea before but no one has done it. Just the idea of making custom motor mounts and headers is enough to make most people stop right there.
Quick Reply: V6-V8 swap: How to
