V6 to a V8
Old Feb 9, 2007 | 08:08 PM
Sictransit00's Avatar
Default V6 to a V8
statisticaly speaking the z28 is the exact same size except with the V8, so if i were to find one for say at a junk yard if i was lucky and the engine still ran good would i be able to drop it into my 94 V6? can this be done without major adjustments?
Old Feb 9, 2007 | 08:47 PM
ghotachevy's Avatar
Default RE: V6 to a V8
search the forums tons of info you got to change the mounts on frame u gonna run a carb ? if not some other work involved what yr car
Old Feb 10, 2007 | 04:06 AM
i was planning on a straight swap, a same year Z28, mines a 94 so i'm going to try and find around there, 93 - 96 is still the same body and engine bay and all that, i figued reenforcing the engine and mabey another trans, but yeah ill look more into it.
Old Feb 11, 2007 | 06:32 PM
Sinner1Camaro's Avatar
what year is the z28? and ur deff gonna need a new ecu and tranny.. its alot of work you got ahead of u....couple g's....
Old Feb 11, 2007 | 11:33 PM
sooperdewd's Avatar
Um could be BS but I heard for acheap full pachage is like 8 grand or so. Your gonna have to change tranny, ECU mounts, I would think fuel system bigger engine more consumption, but there is a lot of work, Thats why personally Im sticking with the V6 and messing with it, its the same class as a Supra, and those are I-6 The V6 can be fast, just needs some tunes tweeks and love. and I would think after installing the V8 that same amount of money could get you something faster than the V8 if done properly.
Old Feb 14, 2007 | 03:19 PM
thanks for the suggestions and ideas, sounds like it will be a bit easier and inexpensive to just mess around with the V6.
