V6 Misfiring
so when you say cut wire are you talking about a plug wire right. when you used the odd wire did it cut out? it may be better for you to take it in and get a running diognostic on her.
Yea I fixed it. It turned out to be a bad coil pack. You have to pull the wires on the coil while it is running with rubber gloves and a long plier thing. Because all of mine were firing but one side of one coil pack was barely firing. While the other side was fine. Hope this helps.
