v6 2000 Camaro rubbing
Old Aug 6, 2012 | 01:25 AM
the_donace's Avatar
Default v6 2000 Camaro rubbing
Hi,
I have a lowered camaro with 285/40/18 tires in the rear with 1 in spacers. My problem seems a bit bizarre to me because I only rub on the back passenger side. The driver side rear tire is intact with no rubbing. I noticed something when I took off my wheels the other day and bump stops are completely eaten up on both sides, yet I still wonder why the driver side doesn't rub but the passenger side rubs like crazy so much that it popped my right rear tire. I am wondering if the bump stops will keep this from happening again or if I need to do something else. I have also cut the fenders a few months ago (once I did this the driver side stopped rubbing completely). Any info on this would help, I will post pictures later. Thanks in advance!
Old Aug 6, 2012 | 07:40 AM
Chaotic94's Avatar
September 2011 ROTM
Time to pull out the 2lbs sledge and beat the inner fender in an inch or so
Old Aug 6, 2012 | 07:44 AM
Chaotic94's Avatar
September 2011 ROTM
Another thing to think about is that if your car is lowered, you absolutely have to have an adjustable panhard bar to compensate for the side movement that the lowering springs make. That is most likely the reason you're only rubbing on the passenger side. Pick up an adjustable panhard bar ant take it for a 4 wheel alignment.
Old Aug 6, 2012 | 03:11 PM
the_donace's Avatar
hmm i see, what's a panhard bar? (sorry im a newbie lol). Either way, my car just seems to sit lower on the rear passenger side than on the driver side so the 4 wheel alignment might give that a bit of a fix.
Old Aug 6, 2012 | 04:01 PM
Chaotic94's Avatar
September 2011 ROTM
Yes but you have to have the adjustable panhard bar to do a 4 wheel alignment. The panhard bar goes from the left side of the axle to the right side of the frame at an angle. So if you lower the car, it will move the rear end slightly to the drivers side causing it to rub on the passenger side. SummitRacing has some good stuff. Should be able to find a single adjustable panhard bar there for reasonable.
Old Aug 6, 2012 | 04:49 PM
the_donace's Avatar
BMR Suspension PHR002R - BMR Suspension Panhard Bars - Overview - SummitRacing.com
that what you're talking about? and I only need one right? okay well I've ordered some z28 bump stops as that's what I've seen recommended in a few threads relating to rear rubbing on a lowered car. I'll see how that goes and I'll probably end up ordering this and of course getting an Alignment. I also recently installed Koni adjustable shocks.
Old Aug 6, 2012 | 04:58 PM
you need cut the sides off the bump stops. brb ok go here and click down a few time till you see the pictures of the bump stop. see if any of that helps http://www.camaroz28.com/forums/whee...2/#post3422887
Old Aug 6, 2012 | 05:01 PM
the_donace's Avatar
even the z28 ones? I thought these didn't require modification. Anyway, how will I know how much to cut the sides to make it fit right?
Thanks a lot for the info guys, this problem has cost me some money lol it must be fixed.
Old Aug 6, 2012 | 05:08 PM
came right back and added to the post, lol. see if the link helps.
you need cut the sides off the bump stops. brb ok go here and click down a few time till you see the pictures of the bump stop. see if any of that helps Wheel & Tire FAQ - General Topics - CamaroZ28.Com Message Board
Old Aug 6, 2012 | 05:49 PM
Chaotic94's Avatar
September 2011 ROTM
Yes that is the right panhard bar btw.
