Turning signals don’t work properly.
What’s up guys, I got a question.
I recently changed my turning and emergency light bulbs in the front, from stock to LED bulbs. Checked how they work and saw that they don’t flash anymore but just light up and stay that way. What could it be and how can I fix it.
Thanks.
Thanks.
RE: Turning signals don’t work properly.
The lighting system with the camaro, at least the newer ones, are very faulty. Usually, when one of my lights go, a couple go at the same time with it. What you're describing definitly sounds like a bad running light, like stated above. There are two bulbs in each side on the front running lights, check those out and hopefully that's your problem.
My running lights are so faulty they melt and crack the bulb, I've heard rumors that the Impalas and Camaros both have something that was recalled about their lighting systems.
Get an electronic variable load flasher. They are about eight bucks at autozone. The LEDs' dont draw current like the standard light bulbs and that usualy causes them not to flash.
dont know if this is how it was back before 97 too, but in mine thats what happens when one of the signals burns out....on camaros they just stay on and dont flash fast like in most newer cars when something burns out
