turbo
Old Oct 12, 2008 | 09:21 AM
hatchetman1025's Avatar
Default turbo
ok i know that alot of the turbo/sc threads are just attention threads but i am for real this time. i hvae been doing some work for a friend andd he gave me a turbo, so i need to make the decision do i remote mount it or do i modify a manifold? can some one help cuz i plan on boosting the camro in a few weeks. BTW 1993 3.4l
Old Oct 13, 2008 | 08:13 AM
JaySan's Avatar
Default RE: turbo
what kind of turbo is it ? T3/t4 , t-70?
Old Oct 13, 2008 | 11:01 PM
Default RE: turbo
its a t3/t4 and i was planning on welding the flange from the exhaust outlet on the turbo to just a few inches past my y-pipe and deleting the cat. and if the turbo sits to low i can cut a hole in my floor and make like a lil hump to have the turbo sit in. then from there run regular exhaust and then run of course the inter cooler piping and so forth.
Old Oct 14, 2008 | 08:19 AM
JaySan's Avatar
Default RE: turbo
I would suggest getting some FFF , Forward facing headers and running it from thererunning it into the intercooler and turbo
Old Oct 14, 2008 | 08:30 AM
cbr600rx7's Avatar
Default RE: turbo
You will be able to mount a turbo in place of the cat. There is too little space.
Old Oct 14, 2008 | 08:45 AM
SpecterGT260's Avatar
Ninja Administrator
Default RE: turbo
do you mean you will not? the sentence was just a lil confusing.
i would mount it in the engine bay. fab up some manifolds and plumbing. and dont go over 6psi
Old Oct 31, 2008 | 12:52 AM
Default RE: turbo
how much hp do u think 6psi will give me? and i know there is no room where the cat is thats y i said i can cut the floor away and make the hump bigger cuz i dont have passenger seats
Old Oct 31, 2008 | 01:32 AM
Ninja Administrator
Default RE: turbo
relocate the battery and do it half way respectable..... 6 psi will probably do 250rwhp ish. maybe on the low end........
the 3.4 isnt designed to take any type of power. fi or otherwise.....
Old Oct 31, 2008 | 09:15 AM
BigNic's Avatar
4' 11" 117 lbs of fury!
Default RE: turbo
you can expect about 7% of your n/a power per pound of boost meaning with the 3.4 start at 160 a litlle over 11 horse power per pound. thusly at 6 psi 66 more horseys so youll be making 220 area....
96V6Camaro
Oct 11, 2021 09:41 PM
Sixty7 Camaro
Apr 11, 2009 12:54 PM
