Anit-Freeze Leak!!
Old Oct 21, 2008 | 11:57 AM
BoricuaHec01's Avatar
Default Anit-Freeze Leak!!
My Maro is leaking anti freeze and when I open the hood the engine is smoking. What's the problem? ?
Old Oct 21, 2008 | 12:02 PM
02StanGT's Avatar
Default RE: Anit-Freeze Leak!!
Smoke or steam? You know where exactly the leak or 'smoke' is coming from?
Old Oct 21, 2008 | 01:22 PM
Im guessing it's steam cuz it doesn't smell like smoke, but my whole car smells like anti freeze and it's leaking from the bottom and when I look in the engine, i see it leaking from the middle of the engine by the belt. The steam is coming from the top of the engine.
Old Oct 21, 2008 | 01:29 PM
97SuperSport's Avatar
That sounds like a bad water pump.....
Old Oct 21, 2008 | 01:34 PM
02StanGT's Avatar
That or the dread plastic elbow that goes from the tensioner to the intake... I hate that damn thing.
Old Oct 21, 2008 | 02:19 PM
Will that cost a lot?
Old Oct 21, 2008 | 02:32 PM
RSSteve's Avatar
water pump isn't cheap, but the elbow is. But the elbow is a pain in the ***.
Old Oct 21, 2008 | 02:38 PM
02StanGT's Avatar
Elbow is about three bucks. You can find it in the aisles at Oriellys. To replace it, you need to remove your alternator, which lets you remove your tensioner assembly, to replace the elbow, which requires you to be able to replace it by feel. Odds are some of it will break in the passage ways and you will have to remove the leftover crap before you can put the new elbow in.
Old Oct 21, 2008 | 10:07 PM
evilkal's Avatar
Mine did the same thing. Replace your thermostat...
Old Oct 21, 2008 | 10:21 PM
importmd's Avatar
what are you talking about..... t-stat housing or gasket, NOT the thermostat.... a bad t-stat will either cause your car to run hot or cold, not leaking coolant and steam, unless its stuck closed then it will over flow into the OVERFLOW tank...but thats not the case here because then he would be also over heating
