trouble shooting error codes
Old Jul 31, 2005 | 02:48 PM
twizzler's Avatar
Default trouble shooting error codes
Alrighty... here's what I'm dealing with...
1998 Camaro, RS v6 3.8...
I've had to change out the MAS, ignition coils, plugs, wires, and I'm getting a missfire still
the error code I'm recieving is: P0175, system too rich, bank 2 (right side)
what is happening is that there are times when the check engine light comes on and goes off again... the engine will run smooth some days and then fairly rough (miss fires like crazy), noticing that weather has an effect at times. I've got an idea that it's the O2 sensors on the exhaust manifold that are going out (pre and after cc). I have replaced those roughly 2 years ago or more. Does anyone here have an idea as to what it may be?
Old Aug 10, 2005 | 09:20 PM
Default RE: trouble shooting error codes
You may want to try the O2 sensors again. The one before the cat controls the mixture, the one after verifies that the exhaust is clean. You may want to move them to the left side & see if the trouble changes to the left side.
It could also be an ignition problem, if a cylider does not fire it will send a slug of unburned fuel into the exhaust making the mixture look rich. The O2 sensor sees the rich mixture and tells the computer to lean out the injectors, making the whole thing worse. It could also be a bad injector on that bank that is dumping extra fuel. You mentioned having changed the ignition coils, did you also change the ignition module driving the coils? They have a habit of breaking down and causing all sorts of wierd misses and crossfires,
Deathiskummin4u
Aug 20, 2014 09:26 AM
Ryan hilsgen
Jan 22, 2012 01:21 PM
Robzilla
Jul 15, 2011 02:18 PM
95camaro95
Oct 7, 2010 05:54 PM
z28pete
LS Series Tech
Jun 20, 2007 06:59 PM
