trouble codes
First thing, make sure your 3000 has the latest firmware (V4.07), if not, update it:
http://autoxray.com/tool_download.php
USB (Universal SERIAL Bus) is a serial port -- if you have the USB Autoxray cable (or you can order it from them).
Else you can get one of these to convert USB to older style Serial 9-pin port:
http://www.tripplite.com/en/products...xtModelID=3914
Im not too knowledgeable on alarm systems, but to get an auto start system on a manual trans, Ive heard they have to do something to the clutch sensor to trick it into thinking the clutch pedal is pushed in.otherwise, the car will not start.
the code 39 must be due to that. there may not even be any problem with it, the computer may just be throwing the code because of the changes made by the shop
