trouble codes
trouble codes
P0112
Intake Air Temperature Circuit Low Input
P1351
Misfire Cylinder 5 With Fuel Cut-off
Intake Air Temperature (IAT) sensor intermittent low voltage
i got these code when i was useing my hypertech for the first time, have not came back since i installed the program, anybody know what is up
RE: trouble codes
Try these links before theytime out. In any event, if the codes did not come back, you have nothing to worry about.
http://www.alldatapro.com/alldata/PR...58043/87277106
http://www.alldatapro.com/alldata/PR...58043/87592817
RE: trouble codes
The first code would lead me to test the IAT sensor for proper resistance and test the wires for proper voltage. The second code, according to http://autorepair.about.com/cs/troub.../bl_obd_13.htm , appears to be a BMW code. GM also shares the same code which is 'Ignition Coil Control Circuit High Voltage'.
