Traction control
Old 05-22-2008 | 05:09 PM
02CamaroV6's Avatar
Default Traction control
Alright i got a 2002 Camaro v6, how do i turn off the traction control? And are there any problems associated with doing this?
Old 05-22-2008 | 05:47 PM
98RCMARO's Avatar
Default RE: Traction control
ORIGINAL: 02CamaroV6
Yes, you will lose traction.
Old 05-22-2008 | 11:20 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
first auto or manual? if auto by shifting into D as oppised to [D] you will turn of tracktion control the only real issue with this other than your car not slowing you down threw turns is that its gonna burn more gas and youll screech the tires more
Old 05-22-2008 | 11:28 PM
GMDCAMARO's Avatar
^ HUH?
Old 05-22-2008 | 11:49 PM
evilkal's Avatar
Traction control turns itself off when you shift out of overdrive mode ([D]) because they suspect you want more power (duh haha). Hence why your car takes off a little quicker when you shift it yourself in an auto =P
typip111
07-21-2011 08:38 PM
Combat_Chuck
04-19-2008 12:03 PM
EggboaT
04-19-2007 05:48 PM
Puck90a
01-30-2007 12:58 AM
KoRN_Munky
05-31-2006 02:30 PM
Quick Reply: Traction control
