Torque Control Arm ?
Old Mar 7, 2009 | 05:51 PM
osduck5's Avatar
Default Torque Control Arm ?
96 Camaro, 3.8 auto tranny. Getting ready to drop the engine/tranny. My first one to remove from the bottom. I loosened the 3 bots on the torque control arm at the rear of the tranny. Will the arm slide out of the bracket once I start lowering the tranny or do I have to remove the bolts that attach the arm to the rear axle? I am hoping not because I already have the rear setting on tires/wheels and it looks as if I will need to raise the body to let the rear axle drop in order to pull the long bolts all the way out. Any suggestions? Thanks.
Old Mar 7, 2009 | 08:03 PM
osduck5's Avatar
Default torque arm removal ?
Never mind! I went searching on the internet and I do believe that someone has already had the bracket off the tranny and just put the bolt in from the wrong direction. Looks like the bracket is 2 pieces but they put the nut on the opposite side from where it should be. Geeze!
clyon
May 1, 2009 09:24 PM
Combat_Chuck
Apr 19, 2008 11:03 AM
73 T Top
Apr 3, 2008 12:51 AM
dzroc
Jun 21, 2006 12:01 AM
