computer code 36???
Old Feb 27, 2009 | 08:27 PM
thetal1's Avatar
Default computer code 36???
i went to pep boys to get my computer read on my 95 3.4 because the check engine soon light is on. It only comes on while i am driving my car. they told me it was a code 36 and that it is computer related. i was wondering it meant and how do i fix it.
Old Feb 27, 2009 | 09:00 PM
02StanGT's Avatar
36 24XSignal Circuit Error (3.4L) Faulty circuit error from coil packs to module.
My Hayne's manual says "the 24X crankshaft position sensor is mounted on the engine front cover and partially behind the vibration damper".
Old Feb 28, 2009 | 06:56 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
I have never heard of a '36 code'.... just 36, its usually 3 or four digits. Like p0136 or something like that.
See if this helps.
http://www.obd-codes.com/
Old Feb 28, 2009 | 11:36 AM
02StanGT's Avatar
It's OBD-I cpl. I just put what it is.
Old Feb 28, 2009 | 12:18 PM
thetal1's Avatar
i looked and now i need to know if i have to replace any of the parts or what. I'm sure that taking it apart and putting it back together wouldn't help.
Old Feb 28, 2009 | 03:09 PM
02StanGT's Avatar
It is a crankshaft position sensor.
Old Feb 28, 2009 | 03:49 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
*sigh* I have a habbit (its new so I cna un-learn it easy) of comming here and simply clicking the link for "new posts" I saw 4th gen and assumed it was obd2. Dont know what I was thinking... I should have looked at your posts before responding.
Old Mar 3, 2009 | 11:53 PM
thetal1's Avatar
alright ill take a look at it and thanks for the help
Old Mar 5, 2009 | 02:40 PM
libertyforall1776's Avatar
Smile
But don't believe it's the sensor. I had the same error on my 3.4L and it was an electrically dead fuel injector that had been intermittent for years! I knew the symptoms of it from its intermittent failing, but never knew the exact problem. Anyhow, this same code is now gone after injector replacement!
Old Mar 7, 2009 | 02:49 PM
thetal1's Avatar
where is a good place to get the fuel injectors and how much are they
