Top Speed on a 3.4l V6
Old May 7, 2006 | 08:13 PM
bigt9063's Avatar
Default Top Speed on a 3.4l V6
Hi im new here and i was thinkin about purchasing my neighbors camaro and i was wondering what the top speed might be on that, and how do u remove the engine limiters, thanks guys
Old May 9, 2006 | 03:45 AM
Raidenvaga's Avatar
Default RE: Top Speed on a 3.4l V6
I wondering about that myself.. I would to get that custom cluster that reads up 200mph on the speedometer, think their all for 97 and v-8 models. looking for someone to get that limit off.
Old May 17, 2006 | 11:53 PM
Charles_M's Avatar
I have a 94 v6 3.4l and i've gotten that car up to 110 before the govenor kicked in and droped me down to about 107-108...if u manage to figure out how to take off the limiter, plz share...i wanna make this car go faster with out limitations
Old May 18, 2006 | 01:59 AM
To remove the speed limiter you have to have the PCM reprogrammed, and have the speed limiter deleted. Be aware that if you don't have speed rated tires, you are risking a high speed blowout. Not much fun.
Old May 18, 2006 | 03:23 AM
Raidenvaga's Avatar
Why do you think we have cheap @ss tires, LOL !!!???
To delete the limiter,Can you use V8 programmer on 3.4 v6 to do that or are you going to a speed shop to do that ????
Please tell, My trouble is at the limit that I need to break !!!!!!!! Hahahahha...!
Old May 19, 2006 | 12:23 AM
Bubonic's Avatar
Also these cars were put at the 110 limit because you will start to wag lol
Old May 19, 2006 | 01:01 PM
I don't think a V8 programmer will work with the V6, it will probably screw up the car. You can call http://www.pcmforless.com/ (they do v6's in addition to v8's) and they will modify the PCM setting to delete the limiter and also retune the PCM and get you a few more horses. They charge somewhere $125 to $150, which is much cheaper than bying a programmer.
Old Mar 5, 2007 | 12:38 AM
94Camaromil's Avatar
Well guys i dont think i have a governer on my 94 v6 i raced a 99 mustang 3.8 and it chipped out at 115 and mine keep it was below the speedometer im thinkin around 120 then i backed off cuz i kicked his ***
DiElSleL
Mar 8, 2012 01:23 PM
DiElSleL
Mar 6, 2012 10:54 PM
rext
67-69 V8 Tech
Sep 23, 2011 11:49 AM
