Tick tick tick
Old Apr 10, 2009 | 01:21 AM
shawnz_90's Avatar
Default Tick tick tick
is the noise i hear a constint speed tick tick tick coming from my motor... any ideas and the speed i hear it is about the speed it takes to read
Old Apr 10, 2009 | 02:05 AM
Saint_Ali's Avatar
sounds like its a valve train noise,could be a number of things...stuck lifter,stuck valve,etc
Old Apr 10, 2009 | 09:59 AM
shawnz_90's Avatar
it runs fine just when i idle it makes that noise
Old Apr 10, 2009 | 10:42 AM
evilkal's Avatar
Which makes it sound even more like a valvetrain noise :P When you press the gas, oil pressure goes up... More lube = Less noise eh? I'm with Ali and say sticky lifter
Old Apr 10, 2009 | 01:54 PM
libertyforall1776's Avatar
Do you use full synthetic oil? If not, try switching and see if that helps...
Old Apr 10, 2009 | 06:46 PM
isaac11's Avatar
Could a stuck lifter cause your car to lose power
Because my car is doing the same thing and Ive noticed a loss in power
Old Apr 10, 2009 | 07:03 PM
shawnz_90's Avatar
i use full synthetic . But if it is a stuck lifter how would i fix it on a 3.4?
UPDATE: the tick is starting to kinda get faster and louder...
just out of curiosity what is the oil pressure gauge supose to be at when idling and driving?
(mine is about half maybe a little less at idle with engne warm and goes up to about 70ish when accelerating)
Old Apr 10, 2009 | 10:36 PM
Saint_Ali's Avatar
Yes a stuck lifter can cause a loss in power,because it is not opening up the valves.Oil psi should be at least 20 psi at idle,but its normally higher when the engine is cold.The rule of thumb is to have atleast 10psi per 1000 rpms
Old Apr 10, 2009 | 10:53 PM
evilkal's Avatar
My car is a 3.8 and at idle it's around 30-35 and 60 under load when the engine is hot. I figure about the same for yours.
Old Apr 11, 2009 | 09:14 AM
shawnz_90's Avatar
heres a list of parts that i have found let me know what you think...
http://www.jegs.com/i/Comp+Cams/249/802-1/10002/-1 lifters. Should i buy 6 or does 6 come with the it?
http://www.jegs.com/i/Comp+Cams/249/980-12/10002/-1 Valve Spring set
http://www.jegs.com/webapp/wcs/store...=MkMdlYrSearch
What Retainer should i go with?
http://www.jegs.com/i/Comp+Cams/249/501-12/10002/-1 Valve stem seals
is all the above nessary?
Here is a cam and lifter kit http://www.jegs.com/i/Comp+Cams/249/CL16-115-4/10002/-1 Will this work and add hp? and if so what all else do i need to fix my problem?
