Thermostat Yes or No??
i have a 2000 V6 Camaro and i was wondering if a lower temperature thermostat would be a good thing or not to get cause what i heard is that it doesn't add horsepower but it opens up options for other mods to add more horsepower is this true and if i was to get a low temp thermostat which one should i get?
Only if you plan on getting a tune on your PCM. You should do at the same time as the tune, because it will cost you HP and MPG until you get the tune. Do your other modes first and install a 160 or a 180 thermo right before the tune.
Your current tune is for 195 temp thermo. If the motor runs colder then that it will be less efficient. But a colder engine can handle more timing advance so if you cool the motor down and add more timing advance in the tune and combine it with better gas you can free up 8-10 ponies. You can get a stock engine tuned but you will most likely see 5 HP increase. A set of headers may add 10 HP. But if you add headers a 180 thermo and a tune you could see a 25 HP gain.
