thermostat
Old Oct 18, 2006 | 11:04 PM
JaySan's Avatar
Default thermostat
Does any 1 know how to change the thermostat ? I have a good idea on how to do it but I am not 100% sure. I have a 2000 camaro
Old Oct 18, 2006 | 11:33 PM
shnormo's Avatar
Default RE: thermostat
Follow the top radiator hose. Then where it enters the block, there is the housing. It comes off with two bolts. Scrape the old gasket, take the old one out, put the new one in, put the new gasket in, torque the bolts, reattatch the hose and refill the system. There are two gaskets, the paper one and then there is an RTV like substance. If you can get the paper one, that is better.
Old Oct 23, 2006 | 10:23 PM
JaySan's Avatar
i no that thermostats increase performance but what exactly will it increase and My camaro has an o-ring instead of a gasket is that normal?!?
Old Oct 23, 2006 | 11:52 PM
MadMikeZ28's Avatar
The thermostat, depending on temp range, will keep the engine cooler. If the engine gets too hot then there is a loss of power. And the "o ring"is normal.
Old Oct 24, 2006 | 01:18 PM
Deezil13's Avatar
Is putting a new thermostat into my car worth doing... i was thinking about putting a new 160 degree thermostat into my 2.8 then chipping it. I found them on autopartswarehouse.com and they have them for my car so i wanted to know if it would have a noticable boost of power?
SalsCamaro2000
Dec 14, 2011 12:38 PM
MaxTheKiing
Jun 22, 2010 11:30 AM
bluovlh8er
May 17, 2007 02:05 AM
RJayS.
82-92 V8 Tech
May 16, 2007 10:25 AM
bowtie.runner
May 7, 2007 11:32 PM
