Tail Light
Old 06-11-2006 | 10:14 PM
BoondockSaint862's Avatar
Default Tail Light
My turn light/brake light went out and I wanted to know if anyone knew how to change it? I looked at it and I didn't see any way to pop the cover off or take the bulb out. Also, if anyone knows how to change the front turn signals, would you please let me know? Thanks for the help.
Old 06-12-2006 | 12:21 AM
Default RE: Tail Light
Open the rear hatch, pull the trunk liner out at where the hatch closes. You will see some large plastic wing nuts, 3 or4 for each tail light. Remove the wing nuts and push the tail light assembly out. Now you can twist the light bulb connectors and remove them from the tail light with the bulb attached. Pull bulb out & replace.
Old 06-12-2006 | 01:01 AM
Great. Thanks for the help.
lonestarshinedown
06-08-2015 01:39 AM
Dillon5224
02-19-2010 03:53 PM
DyingYoung
11-06-2007 10:31 PM
350rs
07-18-2006 01:42 AM
