Tail Light
My turn light/brake light went out and I wanted to know if anyone knew how to change it? I looked at it and I didn't see any way to pop the cover off or take the bulb out. Also, if anyone knows how to change the front turn signals, would you please let me know? Thanks for the help.
RE: Tail Light
Open the rear hatch, pull the trunk liner out at where the hatch closes. You will see some large plastic wing nuts, 3 or4 for each tail light. Remove the wing nuts and push the tail light assembly out. Now you can twist the light bulb connectors and remove them from the tail light with the bulb attached. Pull bulb out & replace.
RE: Tail Light
Great. Thanks for the help.
