T-top conversion
It doesn't work that way lol. The hard part about T-top conversion is all the little work involved. All you need are the T-tops and seals really lol.
Anyway, you do realize you can adjust your pin receivers to tighten them down, don't you? If you remove the trim pieces where the pins go through, you'll see the receivers. Loosen the two bolts from underneath and you can slide the receivers. Move the back ones towards the front and front ones towards the back (with the tops latched in place), then tighten down again. Even if you don't have a leak, it would be good to make sure the top pins are catching by enough. Some guys have had their top fly off because the latch pin wasn't catching the receiver by very much.
on ebay t-tops are goin from 50 (just one side) to 200 (both sides). Then the stripping is the same deal 100 and up for that. And the shades that go underneath are expensive.
get a doner car JMO
