t-56
Old Sep 12, 2007 | 09:46 AM
ninetysixyenko's Avatar
Default t-56
can a t-56 tranny fit on a 3.8 motor, to replace a t-5?
Old Sep 12, 2007 | 11:25 AM
02StanGT's Avatar
Default RE: t-56
Anything can fit, with a little alterations... Try these sites for more info:
http://www.gilbertchevy.com/frame.ht...n_3/index.html (granted it's for the 3rd gens, but maybe they know how to help, or what you might need)
http://www.ttcautomotive.com/English...s/T-56.asp#Car
Old Sep 13, 2007 | 12:28 PM
squisher's Avatar
Default RE: t-56
Most likely you are going to need an adapter plate, unless somebody makes a bellhousing for the T56 that has teh V6 bolt pattern. The clutch might be tricky too, as far as finding the right one. I don't know how big the clutch for the T56 on the V8s is relative to the clutch on the V6 T5.
Old Sep 13, 2007 | 12:45 PM
Default RE: t-56
well, i thought maybe the t56 would fit right on, cuz, my friend has a 95 z28 5 speed. he said it wasnt a factory option, he ordered it specially(he's owned it since 94) and he has the t-5 in it... so i thought if a t-5 cant bolt onto a Z, then the t56 should be able to bolt onto a 3.8. thansk for the help. it dont look like it would lol.(this is for another firned of mine's car)
Old Sep 13, 2007 | 02:27 PM
Redneck97's Avatar
Default RE: t-56
Well a t-56 would be useless ina 3.8....you wouldnt make enough rpm's to make use of the 6th gear....unless your going about 85 on the interstate....
Old Sep 13, 2007 | 06:42 PM
Default RE: t-56
85 isnt that fast for north way round here lol. and my friend is doing same thing i wanted to do, stroked, and procharged 3.8.. i told him he mite wanna look at a 6 spd tranny. so i figured i'd ask for him.
Old Sep 13, 2007 | 07:17 PM
Chappie99's Avatar
Default RE: t-56
I have no need for a 6 speed...@ 80 MPH I am reving 2200 rpm in 5th gear..
Old Sep 13, 2007 | 07:24 PM
Default RE: t-56
woah, really? going down highway at 75-ish i was at bout 3500 in 5th.. but then again, i beleave the rear end in it was messed with, it didnt have posi code, yet it was a posi.
Old Sep 14, 2007 | 08:15 AM
squisher's Avatar
Default RE: t-56
The T5 on a V8 isn't much of a stretch, I believe that they used T5's in third gen F-bodies (IIRC), so having a bellhousing with the V8 bolt pattern is no surprise. I'd be more surprised if they had a bellhousing for the T56 to attach to the V6.
6th gear being too tall in the T56 could be fixed by isntalling a shorter rear-end gear, which would give you pretty nice acceleration through the rest of the gears, and then a really tall 6th to bring the revs back down on the highway, so I can see there being some benefit, not to mention that the T56 is supposed to be a monstrously strong trannie.
2200 RPM at 80? That's seems like tall gearing for a 6er, I turn over about 2600 or so at 75-80 mark.
3500 in 5th for 75-ish is definitely short geared from stock, my Cavalier ran 3k at 80. I bet your car pulls like mad with gears that short!
Old Sep 14, 2007 | 05:57 PM
Default RE: t-56
i dont have it any more, but yea it did, i redlined in 5th at bout 95/100, i could be thru 1st 2nd and 3rd, into fourth in about 8 seconds. 1st redlined about 19-ish. i could spin em(with 10.5 inch wide tires) in 1st and 2nd.
thats what i was thinking about with like 3.73, maybe 4.10 gears in rar with a t-56, then tlike u said the fact they can handle alot more torque.
i was told by my friend with the Z with a t-5 that a 5spd is s'pose to be better for dragging than a 6spd.
i still wanna do my supercharged stroker 3800 project. lot of mula tho, and need a new camaro(have ION atm.)
