stuck exhuast
my exhasut won't come out I took off the cadilytic converter and exhaust there all disconected but hte exhaust pipe that comes from converter to muffler wont come out it an be slid and move aroudn but it won't move over the axle and I don't feel like cuting it I mean I most likly am going to just replace it how to I pull out the exhuaust?
thanks Nick
thanks Nick
If your trying to remove the whole pipe then you have to cut or drop the rear. If you are trying to pull apart where a clamp was they usualy get crimped so a couple of slices through the outer pipe and pry it open and twist and jerk and hammer and.... and it will come apart. Then when you reassemble you slip it back together and clamp it up.
so if you can't take apart were the clips are cause there are no clips then and it just 1 big exhaust then it has to be cut or the rear end has to be droped is that correct?
How do I go about puting my new one there then? I was thinking welding it but how cause its so close to gas tank kinda scary but I'll do it. I don't think ican clamp it though
Thanks Nick
Thanks Nick
