gas oct.
Old Feb 15, 2007 | 05:01 PM
bluovlh8er's Avatar
Default gas oct.
is it weird that my car seems to have more power at 87 oct instead of 93?
Old Feb 15, 2007 | 05:50 PM
Default RE: gas oct.
That is very possible, if the compression is not high enough, or spark timing set to take advantage of the higher octane. Your car is factory optimized for regular.
Old Feb 15, 2007 | 06:09 PM
bluovlh8er's Avatar
thanks pete. i just figured you know you pay for what you get. tell you what, i was filling up my car and got a lil bit into a can for the snow blower, runs damn good on the 93 lol.
Old Feb 15, 2007 | 06:39 PM
MadMikeZ28's Avatar
You get more of a complete burn. As long as your car does not knock where the computer needs to adjust timing all the time you can use the lower octanes.
Old Feb 15, 2007 | 07:27 PM
I think anything works in a snow blower, got mine going on laquer thinner cause I forgot to buy gas. Kinda rough on the eyeballs. lol
Old Feb 15, 2007 | 11:11 PM
Pro_built7's Avatar
do you guys think 87 or 89 octane makes a difference ?
Old Feb 15, 2007 | 11:40 PM
MadMikeZ28's Avatar
ORIGINAL: z28pete
A former employer of mine would coast into the parking lot of the shop in his super beetleand yell "Michael, I know you have an empty Dr. pepper bottle around here. Pump 16 ounces of laquer thinner into my tank so I can get to the gas station".
Old Feb 16, 2007 | 12:05 AM
bluovlh8er's Avatar
will 89 be better then 87?
Old Feb 16, 2007 | 02:12 PM
One is not "better" than the other, but they are different. As long as the car is basically stock, you need to use the one that the car was designed for.
Old Feb 16, 2007 | 03:01 PM
BZ89's Avatar
Ive been running 89 in mine seem that she runs just little bit better and ive had less problmes
